1) Can I book a test drive? 2) I have enquiry regarding price. 3) Can I please have more information on service history? 4) Hi, Just viewed your listing and will like to purchase it. can you advice on how long you have had the vehicle, why you are selling it, has it ever been damaged, what condition is it in, will it meet a RWC, does it have any bad habits and your final price? I will be Glad if you can send me some pictures.. Kindly get back to me as soon as possible. Awaits your response Steven
Can I please have more information on service history? Please kindly advice on the final price and the present condition...
Interested in your listing,can you send more pictures(insideespecially) to martianlabelle(at)gmail(dot)com.Regards
^ Enquiries about a car I have for sale on drive.com.au, are these scam replies or legit do you think? If scam, what blipped on your scam radars?
Car is a 2006 Alfa Romea GT Selespeed
legit.
no mention of kenya.
Well it's not my Alfa :P It's listed at 16,000 atm... would explain why it's had no bites for 3 months...
Then suddenly 3 in 2 days... from separate people...
The first one looks the most suspicious... I mean, why would his point #4 start with "4) Hi, ", sounds like a copy pasta
The broken english concerns me, though after seeing posts on drift sales, not much phases me anymore.
Sif not swap for a 33
Soooo... trying to sell daily bcoz company vehicle, but swap for unknown condition R33 so I can sell the parts for more than what Evo 8 parts go for?
profit?
dat SAU logic
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
