ahk, just thought maybe you'd read one of their brochures or something at lunch time. or receive those wonderful corporate emails about employee deals etc.
Employee deals are 21% off
Hope you guys aren't being serious
Just because you lodge a tax return doesn't mean your automatically entitled to a refund
For your average John Doe your refund is more dependant on your employer rather than the Tax Office or Accountant
got my best return in years this year. :cheers:
Edited by alr33x
Do they?
What sort of interest rates do they offer?
Normally they offer absurdly low interest rates (losing money) but then they don't discount the vehicle as much to make up for it
Just had a snoop on their website and the financing link is a dead end. they do their own insurance as well...
Anyone got some good tips for bleeding an empty clutch line?
Lol I definately need to do mine as well...
At DECA I could hardly get it into gears once it was really hot because the clutch wasn't fully disengaging... Dat crunch
When I was in 1st with my clutch pushing hard against the floor, if I revved at all it would creep forward :/
Their own = Outsourced to a supplier of credit / insurance with a slightly better rate for kickbacks?
Bleed it first, if that don't fix it, it could be the pedal position screw on the master cylinder needs adjusting.
Do they?
generally they wont negotiate one dollar on purchase price when they advertise super low interest rates, i know honda while ago had a deal on finance but it was a 50% up front payment like if you go 50% of the cars value available to you pretty sure 3% finance isnt that important.
also my mates got bmw full circle so you get a guaranteed amount for the car in 3 years or whatever but you gotta to less then a set amount of kms per year and dealer service etc. always a catch.
No mods to fit and will give the power I am shooting for
fair deal. kits you need for an e9 framed turbz don't seem to be too dear, but if you don't need them for your goals, no point. when does the stock 7 turbz start to struggle though? i thought it could make 220-230 or so...?
Empty line needs a bit work work though :(
$50 off ebay.
nah the 7 turbo is tiny, not much more than 200kw on 98, tad more on e85
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
