ahk, just thought maybe you'd read one of their brochures or something at lunch time. or receive those wonderful corporate emails about employee deals etc.
Employee deals are 21% off
Hope you guys aren't being serious
Just because you lodge a tax return doesn't mean your automatically entitled to a refund
For your average John Doe your refund is more dependant on your employer rather than the Tax Office or Accountant
got my best return in years this year. :cheers:
Edited by alr33x
Do they?
What sort of interest rates do they offer?
Normally they offer absurdly low interest rates (losing money) but then they don't discount the vehicle as much to make up for it
Just had a snoop on their website and the financing link is a dead end. they do their own insurance as well...
Anyone got some good tips for bleeding an empty clutch line?
Lol I definately need to do mine as well...
At DECA I could hardly get it into gears once it was really hot because the clutch wasn't fully disengaging... Dat crunch
When I was in 1st with my clutch pushing hard against the floor, if I revved at all it would creep forward :/
Their own = Outsourced to a supplier of credit / insurance with a slightly better rate for kickbacks?
Bleed it first, if that don't fix it, it could be the pedal position screw on the master cylinder needs adjusting.
Do they?
generally they wont negotiate one dollar on purchase price when they advertise super low interest rates, i know honda while ago had a deal on finance but it was a 50% up front payment like if you go 50% of the cars value available to you pretty sure 3% finance isnt that important.
also my mates got bmw full circle so you get a guaranteed amount for the car in 3 years or whatever but you gotta to less then a set amount of kms per year and dealer service etc. always a catch.
No mods to fit and will give the power I am shooting for
fair deal. kits you need for an e9 framed turbz don't seem to be too dear, but if you don't need them for your goals, no point. when does the stock 7 turbz start to struggle though? i thought it could make 220-230 or so...?
Empty line needs a bit work work though :(
$50 off ebay.
nah the 7 turbo is tiny, not much more than 200kw on 98, tad more on e85
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
