Spot on Hamish. I literally can't understand how anyone (let alone a majority) voted for.
Using just my facebook as an example, I've seen maybe 2 people post that they voted for/are happy Liberal won. One of them is an asian chick who is literally the most materialistic person I know, whose name I won't mention as people on here probably know of her. Her constant posts/photos telling the world how rich and 'classy' she is make me sick to the point that I deleted her.
My only hope is that these people get f**ked over in Abbott's term as well.
Oh yeah her!
f**k tradies, we're just overpaid deadbeats who should be on sub McDonalds wages and work in life threatening conditions.
Right Liberal voters?
I vote Liberal and in no way think that :)
Also Hamish, I am concerned that you truly hope Tony Abbott is murdered. Even though it's likely/hopefully an exaggeration, it's a very poor way to push your case. Dat Labor compassion lol
It's that east coast mentality. All about guns blazing and killing people. That's not what guns are for. They for slipping hoes .44s so they can get in the back door etc.
westcoast4lyf
But what about the 3 daughters, dayum.
Check this out, the media already all over the motoring enthusiasts:
http://www.heraldsun.com.au/news/six-people-you-won8217t-believe-could-be-elected/story-fni0fiyv-1226715202378
Hamish, your point is valid its not only about money however they wouldn't be cutting it if things weren't in such bad shape courtesy of Labors terrific job of burning down the electorates houses with the genius batts idea, or the school building project which gave schools things they didn't even want!
also voting liberal is not voting abbot, you support the party not the person just like football.
Dezz - don't take this the wrong way but it would make sense the majority of your friends etc voted labor as they are likely similarly minded and employed as you are for the most part. Liberal voters are clearly less vocal as my Facebook had epic amounts of labor lovers which i refrained from commenting on as half of it was to stupid to argue with. My mates all voted liberal but none bothered to take to Facebook and have a meltdown.
Clearly i voted Liberal, always have always will i dare say, but this welfare country has to stop its beyond a joke. Its a bit rich to suggest liberal are leaving the mess when the facts would clearly point to it being the opposite.
anyway time will tell, but i for one am wrapped to have Liberals back in charge, sure as shit couldn't do worse than krudd / dullard.
Edited by alr33x
this was said everywhere in england after the conservatives/liberal replaced labour.
f**k where they wrong.
Yeah well this Ricky Muir should take his shit seriously if he's going to, everything he's ever done in the past is going to be scrutinised, so step one would be cleaning up his facebook page, or taking it down completely and adding a proper support page, which has comment moderation turned on.
well this is Australia. compare Liberals track record to Labors over an extended period and its almost laughable that anybody would vote for such a rabble. Forgive me if i'm mistaken but labor in England also left massive debt behind?
but hey everyone's entitled to an opinion.
Edited by alr33x
Yeah Ricky Muir needs to be replaced with a 60yo guy who owns an old pony that he's restored from the ground with his kids, and takes it to cars shows every weekend with his family.
Ricky Muir needs to be replaced by a 60yr guy who builds go karts for his kids who race competitively and does street racing on the side to feed his amphetamine addiction.
he'd get shit done.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
