nah I haven't really mentioned it anyway as I was hoping she would come back, but I think she has gone off to die now
she had 14 seizures in one day and even after taking medication took her two days to stop, then she laid down or backyard for about a week. Then one day randomly got up one morning, attacked one of our chooks and ran off down the driveway into the paddock across the road. Went to look for within 10 mins as dad left for work and she was gone, searched everywhere and even called the ranger but nothing.
Problem was she was on meds and now she's not which means she will be back to having seizures and just slowly dying as no one will be able to feed her.
Even having really strange dreams about her coming back or randomly finding her so it made it even harder to accept
f**k mate. im sorry to hear that.
Well cousins forcing me to go have a look at it tonight... forgot I even owned that thing
2 months off the road...
Mine was off the road for 6 months.
Thought you'd pull through with this, cause I remember you saying, you were going to prove everyone wrong.
f**k man I don't even know how to react to that! Can't imagine what it's like.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
