Will go looks amazing for $50
N64 are like $150 now FFS
managed to get one with mario cart for $100... ghey but since mine got thrown out by accident it had to be done :/
That's alright
@Plattsy I actually do think snes are holding more money anyway lol
and if i asked a male mate to that place, would it be considered ghey?
No, it could be two mates going out for a beer and good tucker.
This is ghey... :P
Wont be running E85 just yet if thats what you're asking. Not many documented, tracked pulsars on E85. I know of one, and his hasnt run the same since. We'll see how this setup goes with the current turbo first on 98, and will weigh up E85 later.
the courses will be small but I am hyped! That deconstructed lemon cheese am dish that is the last photo in that album is the only one I have had and it's f**king rediculously good! And to get that last time it was in a $1000+ meal
I hope it was good for you Tony
He let me go for a wild ride
no joke
Clayton aye. Close to home i'll check it out
yeah, sweet. bike riders running around like they own the roads, stopping traffic, running reds, wrong side of the road.
pretty sure none of it would have happened if they just let the dickbag in the rangie go past them instead of taking up however many lanes.
i cant say what i would have done in his situation, but it would be pretty intimidating being stopped by what looks like 100 or so bikes and having them all approach you.
i'm not on either parties side, i just think they all acted like a bunch of dick bags, (including the rangie driver) and it all could have been avoided
who is this and why is he on the fence?
As you can see, there's a bitch in his way, that he needs to move.
lost it
http://www.news.com.au/national-news/victoria/woman-dies-10-in-hospital-after-toxic-chemical-released-at-sunbury-motel/story-fnii5sms-1226732023320
For what purpose would someone in a motel release Hydrogen Sulfide and what is it normally used for?
fart gas
damn :(
next saturday.... will have to take a different lady friend ;)
I';m very happy with the Drift Ghost HD. nuff of this GoPro stuff. do need a new mic though just dont have to worry about crappy cases and skeleton things
any body wanna play indoor soccer on friday evening in frankston. theres a couple of guys needed.
ive been six times, and havent had my car stolen or been stabbed. its good fun actually.
then again if i was a dodgy kent i wouldnt try to stab me either.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
