this happened....
was during the cannonball run... driver and co-driver died as did the 2 officials they ploughed through
if you are too young to know what the cannonball run is i will just kill myself now.
this happened....
back when the cannonball runs were done at speed.
well the full story.
there was a cannonball run in AU between Darwina nd perth.
there were a number of check points along the way.
SO rules were you had to slow down to around 100 for the check points and towns and full throttle in between, this guy came into the checkpoint at about 250ish..and lost it,
race cancelled, ppl died..
Ham what a cheap paint job did not even do the door jams ;)
this happened....
I know what the cannonball run is just didn't know of this accident :) waste of lives and ferarri :(
Apparently the 285 18 Achilles 123s are better bang for buck and cheaper than 265/35/18 Federal RSR.... AND they're about the same width because RSR's are wider than 265's should be so will fit under by rear end without needing to roll any guards?
Thoughts? Comments? Which tyre should I go for now that I've decided to do Winton on the Friday before DECA in Nov?
Edit: Just need the 2 rears, 18x9.5 (can't remember the offset...) since I've still got enough RS-R on the front to last a few days.
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
