Are you serious about turboing the micra?
yup. not for a while tho.....
Ceramic wheel 32 GTR turbo? Naice.
Lets bolt it on Platts. :)
they are gtr, not sure if 32 or 33 tho....
and not yet dude.... gotta rego and rwc the pig first!
have to find a way to deal with fuel pressure, but the car will run 5psi with out anything else.... doesnt need injectors ecu anything. just zaust and manifold.
hahahahaha.
Like the mech will pop the bonnet for rwc. lol.
hahahah. if you gotta dodgy one then im down.
if not, it can wait. knowing you, youll wanna put all sorts of fancy shit on it, flux capacitors and the like.
I could think of a few mods...
What can you knock off from work? :P
hahahahaha. i got a few tasty things in here at the mo, but they are leaving in an hour. no chance of knocking em off!
When he sees Paul he will check that it's not an explosive
you saying i look like taliban my friend.....
At least then it might do 88mph
hmmmm still might be a push.
They're 33R.snails
still ceramic tho?
Yup still ceramic, I guess you could always chuck an ebay N1 rebuild kit through the broken one if you wanna shove more boots in :P
thats a good point!
but i doubt ill need any more power than stock mate-torque steer is a killer.
and the only lsd avail, is a nismo one at about 4 grand.
For me, fishing is not about catching fish, it's about hanging out with my mates in the sunshine with an esky full of beer and talking s%#t
Though... This is the last fish I actually caught... Was a 14kg Mahi Mahi... Gave it to the place I was staying at and it was cooked in a traditional oven underground and fed everyone. notbad.jpg
428392_10151358304916746_2082240263_n.jp
http://upload.wikimedia.org/wikipedia/commons/c/cf/MahiMahi-bull.jpg
mahi is 9kgs max. defs not a 14kg. just sayin.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
