Ok I'm not going to the Geelong show anymore
So now I have two pit passes at $135 each.
Free, find me and pick them up.
Pm if u want them
fark! would love to go. but as usual, i have f**king plans.
Tyres on my Type R rims are 195/55, Bridgestone Grid II & Yoko DNA GP, should just buy thems and adapter spacers, HERRAFRUH
bahahahaha. i just want 20 used tyres for now. i have no needs for grip. just a rwc lol
Im surprised he will drive all the way to the east to pick em up
inb4bails
Drop off some of your sausages on the way past moh. nohomo
I know he will. So whoever comes first gets them
