Just got that fun "go kart" feel that you get from a little buzz box; cockpit interior, in tune with the vehicle controls/feedback. You have to hit the corners though. They are no more special than a sporty little modern-looking car around town. I think they did a good job of capturing the essence of the AE86, being that it wasn't the fastest car at the time (still decent performance), but people loved to thrash/chuck them about. A lot of Hondas like the Integra and Prelude are like that. Would I want more power from factory? Yep. But it stands on it's own where it matters. Be a great beginner track car if you can afford to spend that on a track car.
Add a blower and I think that's the difference between 8/10 and 9.9/10.
Hmm... So for just cruising from/to work with squirting there and there, I'd better off keeping my 34 instead no?
Clever security too :)
Xray machine showed a slight gap near the top of the piston...they got greedy and made the cavities too big.
Depends. In the end it's a newer car, more comfortable and better looking than a Skyline. If performance is what you want and you're driving to and from work, keep the Skyline. Like I said you gotta take it to corners to feel the performance side of it. Without corners it's just a good looking sporty coupe with some nice modern features and interior.
I should be there.
And Dezz e60 M5. Dat V10 noise! Drool!
Awesome! Keen to see your 34, looks dope in the pics. :D
I'll make a post about pre meet tonight for anyone else interested.
Haha bit of wider fenders, plastic dip and some rims and shell be sweet
I considered getting one as a family car in the future. But hear maintenance costs can get quite high if something goes wrong. Especially the gearbox
But I love the sound of a V10 :merli:
need some Neesan help
2 plugs near IACV. one brown, one purple. Mein car has brown plug ok, but nothing to plug into purple plug. and engine-conversion loom doesnt have one nearby that fits. Any idea what they do?
(theyre right next to each other)
Yeah purple is definitely a solenoid, I remember replacing the copper washer on my 25, Not sure what the other bit is but I'd imagine it's probably the part that actually moves to open and close the AAC valve, from memory there's a spring inside that area. Manuals and FAST don't go into any detail about what's what because you're supposed to just replace the whole unit when it breaks instead of fixing them :/
Will be properly looking into these supercharger kits for the 86 on Monday. From what I gather: 4-5k fitted, ADR complianced and engineered, all bolt on components with ecu reflash. 170rwkw without an exhaust on conservative boost; not uncommon to get 210rwkw from an exhaust and a little more boost. In a great handling 1200kg rwd, that's good/dangerous fun!
So a r32...? :P
Looks like I gotta find one to drive and see what it's all about for myself.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
