Has he got a good rep? Is he a pro?
Is it just me being paranoid of a guy coming to your house to install an alarm in your car lol?
I also need mine sorted out. some can vouch for how ridiculously loud it is and it automatically arming everytime the battery is disconnected is a right kÜnt to disable it.
Was planning on taking mine to Southland Auto Electrical, and its been recommended by SAU. (also to get battery drain sorted)
Oh haven't heard of them
And i did SAU searches too lol
If only Chris Rogers was Melbourne based!
Ha, this is a 3 minute walk from my work, I've had a few small things done there...
They don't just do Electrical either, they did an engine swap on a workmates Beta-Romeo GT and did a good job with it...
But when I first went in there it was to ask them to diagnose my jumpy tacho (the normal r33 problem, before I knew it was normal) and he said it'd be about $1000 in labour since they'd need to pull out the entire dash to look at all the wiring.... yeahrightiom8byebye
0-100 times is exactly what its designed for. drive one and see, the gear ratios are highly annoying for street driving and not balanced enough for track use. interior is cheap and uncomfortable and steering wheel isnt very nice either. You'd struggle to fit a seat of your choice in there because of the tiny cabin and restricted sitting position. The steering wheel size is comparable with a go kart, but you cant get any bigger because otherwise you wouldnt get into the car. No matter which direction you look, the view is restricted, even the front windscreen. blind spots the size of trucks and cant see out the back of the car making reverse impossible. I dont even know if there is a factory option for reverse camera.
im 5'10 and it was squishy. no fish eye in this pic
One of the nsw Guys has an exige as his daily, he loves it.
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
