fkn too hot today...
my car alarm speaker died.
just started going off at full volume, didn't respond to the remote, open bonnet (loud as an air raid siren in a small concrete room) use the key, still no response.
WILL NOT TURN OFF
so of course I did the only manly thing possible and ripped it out.
once in my had it started popping and cracking. dropped it on the ground and it made a few big explodey type noises.
riiiiiiiiiiiiiiiiiiiiiiiiiiight
so i still have an immobiliser but no sounds :/
Sounds like a battery backup battery melting down and shorting out and exploding with the heat...
lern2flavour fgt
salt and caramel is like popeye and spinach
Nah it's garbage. Well aware of it's etymology but doesn't stop one from spoiling the other. Caramel stands on it's own.
ice cream is only really needed for milkshakes if you dont have coconut cream.
zooper doopers all da way mang
changed oil, filter and fuel filter after work so havent got much left to do tonight except pack tools. so will go to christmas light spectating to run oil in a bit.
Haha see ya there!
You do need a few km' for dat 1000km aye
/thread
and when you are almost done with the tub bowl, the melted icecream at the bottom hides choclaty nutty goodness. I need to get me some asap
da fuq? people put coconut cream in milkshakes?
I went back to the old theme and it was all good... But nooooooooooo the forum has to be smart and bring me back to this shit.
Stop f**king updating the f**king forum Christian f**k!
stripped the sump plug on the Honda...cant change oil :/ cant find vice grips to undo plug...f*k it all...
wheres Aaron
i got him a pressie.....
996772_672611916092708_711109815_n_zpsba
Seriously try it, you'll never look back.
other day did real passionfruit pulp, coconut cream, milk, ice. blend. good stuff. blueberries go the best though/
damn... i snapped an aluminium sump plug on the car today, luckily it screwed out and there was another one lying around.
like white chocolate occasionally, but dark chocolate hits the spot for me (not over 75% though)
well , i guess you win the who f**ked the sump plug the most game :rofl:
I knew this one was f**ked...has been for years but i always remembered as long as I used the right ring spanner it was ok...stupid me put a socket on it...that was the straw that broke the camels sump plug
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
