6 months ago I was talking to a Treasury Estate rep who said they were trying to push moscato onto the younger crowd. I made the prediction that one day it will make it's way into nightclubs as an on-tap, women's counterpart to the men's cider craze. Canning it is half way there. I wonder if my prediction will come true...
I confess to liking moscato and late harvest. If I recall correctly, it was originally pushed as a nightclub/bar drink but never took off. Maybe the timing wasn't right or they didn't have the marketing of today.
Juliette has seen it on tap already....
I understand sharing beers regularly, but drinking beers every night is a pretty bad habit. i know a few of people who drink almost 3-6 beers every week night, and they see it as ok because tradesmen and because alcoholic. But living a hater/hipster/father lifestyle, I thought of it as an oddity.
no, it's an awesome habit... because beer is awesome.
Been on the Oetty's for a while now
http://danmurphys.com.au/product/DM_914086/oettinger-pils-bottles
$29 a slab and I drink a slab a week
based on DM's full price for draught that's a saving of $830 per year for a better beer with no preservatives.
f**king win
Ok, off to dm's
But still need to get moar cash for a plane ticket to Germany for Augustiner Brau.
the cans are a surprise.
but i do like their moscato. pretty pricy though
farkin alvin, moves his dinners so some one can go, now i cant go! ya big bummer!
nah all good mate, ill chat the next one.
So I went looking for some new and engrossing movies to watch and came across this list... then realised that I've seen about 90% of them :/
http://couchpopcorn.com/2012/10/02/20-best-mindf**k-movies/
I've just gone though a comedy phase, and then a infection (non-zombie) phase and now sure where to go from here...
I'm thinking of hitting up all of the Studio Ghibli collection, unless you guys can suggest something that I just should not miss out on seeing. I don't like slow movies, so if its fast paced and engrossing I'm into it :)
k go...
i like slow movies, so cant really help. sorry.
in other news, if Aus did industrial estate sprints, i'd give it a go
I fall asleep or get distracted too easily for slow movies...
Good luck getting a permit for that on the streets, glorifying street racing in industrials would bring all the boys (in blue) to the yard.
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
