6 months ago I was talking to a Treasury Estate rep who said they were trying to push moscato onto the younger crowd. I made the prediction that one day it will make it's way into nightclubs as an on-tap, women's counterpart to the men's cider craze. Canning it is half way there. I wonder if my prediction will come true...
I confess to liking moscato and late harvest. If I recall correctly, it was originally pushed as a nightclub/bar drink but never took off. Maybe the timing wasn't right or they didn't have the marketing of today.
Juliette has seen it on tap already....
I understand sharing beers regularly, but drinking beers every night is a pretty bad habit. i know a few of people who drink almost 3-6 beers every week night, and they see it as ok because tradesmen and because alcoholic. But living a hater/hipster/father lifestyle, I thought of it as an oddity.
no, it's an awesome habit... because beer is awesome.
Been on the Oetty's for a while now
http://danmurphys.com.au/product/DM_914086/oettinger-pils-bottles
$29 a slab and I drink a slab a week
based on DM's full price for draught that's a saving of $830 per year for a better beer with no preservatives.
f**king win
Ok, off to dm's
But still need to get moar cash for a plane ticket to Germany for Augustiner Brau.
the cans are a surprise.
but i do like their moscato. pretty pricy though
farkin alvin, moves his dinners so some one can go, now i cant go! ya big bummer!
nah all good mate, ill chat the next one.
So I went looking for some new and engrossing movies to watch and came across this list... then realised that I've seen about 90% of them :/
http://couchpopcorn.com/2012/10/02/20-best-mindf**k-movies/
I've just gone though a comedy phase, and then a infection (non-zombie) phase and now sure where to go from here...
I'm thinking of hitting up all of the Studio Ghibli collection, unless you guys can suggest something that I just should not miss out on seeing. I don't like slow movies, so if its fast paced and engrossing I'm into it :)
k go...
i like slow movies, so cant really help. sorry.
in other news, if Aus did industrial estate sprints, i'd give it a go
I fall asleep or get distracted too easily for slow movies...
Good luck getting a permit for that on the streets, glorifying street racing in industrials would bring all the boys (in blue) to the yard.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
