you know who got the numbers and CVV on the Austrlian government MasterCard? aboriginals. $6.2 billion a year. ouch.
I didn't know much about the Marbo stuff and land rights. who needs casino's eh?
don't teach us that history in school. all we copped was federation and some other stuff I've wiped from my memory.
the government has started a program by contracting a company to setup 32 General Stores in outback areas with aboriginals, and sell decent foods to encourage and teach good dietary habits. the people who apply to run the shop get a house to live in and $52,000 a year to run the shop, regardless of how much money the shop makes. the contractor supply the food etc and the government foots the bill. not including that a lot of te aboriginal income spent at the shops will be from the government too.
Hey guys quick question not worth starting new thread over:
1. Im buying a z32 + nistune with r33 base tune, do I need a z32 afm to run it or does the ecu work with the stock afm?
2. Anyone running a z32 ecu in their r33? Im getting mixed reports now, where I thought they were a pretty seamless install.
Fanxxx
z32 pinout is different
same physical diameter, different pin mappings
also which rb25?
rb25 S1 is 5 pin and rb25 S2 is 3 pin
z32 is 4 pin from memory
but its all the same
power,ground,signal is all that matters
i maintain my opinion that the new 5L ford engine is awesome. so easy to make power out of it.
dam straight!
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-frc3/291365_10150980217398779_1483653352_o.jpg
dat 240km/h in 4th lol
that's a roller dyno too Hamish, not one of those darn happy hub dynos :P
nah but srs
Edited by UNR33L
Back to work today
Ah to late for me
I just went with another shop which was Chris's best recomendation
Don't paint all aboriginals with the same brush from your experience with the city folks you may have run into.
The ones causing trouble are usually the outcasts who have no respect for their family and culture.
Had a good chat with an elder who explained the above.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
