you know who got the numbers and CVV on the Austrlian government MasterCard? aboriginals. $6.2 billion a year. ouch.
I didn't know much about the Marbo stuff and land rights. who needs casino's eh?
don't teach us that history in school. all we copped was federation and some other stuff I've wiped from my memory.
the government has started a program by contracting a company to setup 32 General Stores in outback areas with aboriginals, and sell decent foods to encourage and teach good dietary habits. the people who apply to run the shop get a house to live in and $52,000 a year to run the shop, regardless of how much money the shop makes. the contractor supply the food etc and the government foots the bill. not including that a lot of te aboriginal income spent at the shops will be from the government too.
Hey guys quick question not worth starting new thread over:
1. Im buying a z32 + nistune with r33 base tune, do I need a z32 afm to run it or does the ecu work with the stock afm?
2. Anyone running a z32 ecu in their r33? Im getting mixed reports now, where I thought they were a pretty seamless install.
Fanxxx
z32 pinout is different
same physical diameter, different pin mappings
also which rb25?
rb25 S1 is 5 pin and rb25 S2 is 3 pin
z32 is 4 pin from memory
but its all the same
power,ground,signal is all that matters
i maintain my opinion that the new 5L ford engine is awesome. so easy to make power out of it.
dam straight!
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-frc3/291365_10150980217398779_1483653352_o.jpg
dat 240km/h in 4th lol
that's a roller dyno too Hamish, not one of those darn happy hub dynos :P
nah but srs
Edited by UNR33L
Back to work today
Ah to late for me
I just went with another shop which was Chris's best recomendation
Don't paint all aboriginals with the same brush from your experience with the city folks you may have run into.
The ones causing trouble are usually the outcasts who have no respect for their family and culture.
Had a good chat with an elder who explained the above.
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
