sure Calder on the 8th?
I still need an oil cooler and fix my suspension for that :/
can I drive
Maybe if the cars not such a handful
I will join teh queue. 385rwkw?! That's crazy, let us know what it's like to drive..
Yeah haven't had a chance to boot it yet. Little scared at the same time
Will be interesting if the hankook rs3 265's and standard diff will be able to cope
need a good wallet leather wallet, need brands and places to buy (not fossil please)
k, go.
My last was a nice Ben sherman one from Myer.
had the drivers license in a pull out with 2 card slots so if you want to travel light it was a good convertible.
have a fossil now..sucks massively no foreign currency fits.
oh btw brahs need advice, D2 racing coilovers or BC BR (gold) coilovers? my hks ones are on there way, one of the shocks is kaput and leaking. :/
Nfi on D2 Racing.
I've BC BR in my 34, can take for spin if you want to see how the ride is, I suppose. No complaints about them from me, anyway.
I would have said 4 minutes but I added an extra minute cause hub dyno
Dat speed hub dyno dependency. You forget, however, if he uses the gutter he'll be able to take corners even faster. #FujiwaraTakumi
Rip Curl
Back 2 High School.
I'm happy with my Oroton wallet.
  • Like 1
man up, i had a few more watts, and what it is when you put the foot down is fun, and mildly smokey.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
