Good location thats all i need to know
Wanted to stay at Orchard rd area but a bit exy
One day I'l stay at the Marina Bay sands when I'm a high roller
Are people allowed to go into that hotel up to the top for fun? Or you need to be a guest/pay etc..?
you mean here:
yeah only guests can go to the pool, there is a bar off to the side at either end that visitors can go to.
Doesn't matter what you put the sticker on, as long as you're not trashing it and generating a bad perception of the club...
Do mike, remove your sticker please.
sad..but mines on my luggage,
some-one tried to walk off with my suitcase one time, so I'm slowly sticker bombing it to make it stand out.
nice,
we goign a week later as
1 want to avoid school holidays
2 as thought VIC time attack would be easter again. (but they changed date to weekend we now fly out!)
3 katie struggles to get public holidays off
heading to krabi for a week, should be fun.
yeah it insane,
I purposely picked a non black one as had probs in the past
So got a blue one. now it seems every-one getting blue ones as black too common, so finally there was some-one with the same one.\ and yeah they started to walk off
So car stickers to identify it,
think will get one of these next tho, and might get it airbrushed..
https://www.samsoniteaustralia.com/bag-finder/travel-hardside/firelite.html
Fixed my wind deflectors today. The clip closest to the front quarter panel came off and the tape was dry, so when I was on the Westgate freeway doing 100km half of the wind deflector came off (looking like it was going to fly away). Lucky it managed to stay together.
Had to completely remove the double sided tape (bitch of a job, still couldn't get 100% of it off) and put new tape down. Also adjusted the clips so now it's completely secure ;)
want to try.
Sunshine two strokes sound awesome fun, but south morang has a great track. wasnt sure if you could hire karts there though
Are you free this weekend? We are doing Go Karts at Ace Karts starting at 10am :)
I've done LeMans, Ace, Auscart so far. There's one in Epping but don't think it's pop in and drive deal.
Also there's couple up north in Somerton and South Morang from what I was told, yet to check it out.
Oh go karts is definitely something I want to do soon!
Used to go a lot when I was younger but haven't been for ages!
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
