signed up for drags at calder after track day. fuggit. already there, car should hopefully be ok, get plenty of runs in. will take 2 sets of wheels and just fill up at the BP on calder fwy (if not going E85 this week...)
Mum moved skyline out of driveway when I was out partying last night... nek minnut 2x brand new XD9's guttered and 2x panels scratched... f**king fuming.
The first set of rims I bought for my 33 back in the day...I was moving them out to the driveway to fit....Mum offered to help, I said nah it's all good I've got it...she ignores and helps anyway...rolls one a few meters and drops it face down... Thanks Mum :thumbsup:
6 day work week, now know that feel bro.
But...1620 after tax for the week...
Toby, does this qualify me for VWLBC?
What's the job?
Just filled up the ute...$104 fuaarrrk
  • Like 1
oh if you genuinely do feel that you "need" the latest phone, please kill yourself now... you have no life... clearly
well the blackberry shit itself. z1 is free. so might as well.
well technically not free. mom had a voucher for $300.
Edited by xALmoN
What's the job?
One is 8:30-5:00 marketing job, the other is Saturday art classes...
You still getting "supplementation"?
It won't be every week that I get that, second job is too seasonal for that to work :(
But while I can it's certainly nice, and a nice change from being unemployed.
Hey Dad, can you please put the rest of the wheel nuts on that wheel? Sure... nek minit cross threaded and new stud needed.
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
