Artz lives in Frankston
Maybe he'll rent out a room
take your acar and get him to give it a rub for ya!
franga isnt as bad as people make out.
i wouldnt hang around the train station tho, and im an evil bastard.
got pulsar back last night, all fixed. hooollly shit. its quick. was supposed to be testing to make sure boost wasnt going over 20psi, I couldnt even pay attention to the speedo. wheel spin in 4th gear is pretty scary lol.
The good thing about Frankston...the police are too concerned with domestic violence and low scale. Theivery to be concerned with modified vehicles. ;)
this.
unless hwy meet.
dont go more than 500meters from the meet on your own or you will be defected.
What was fixed?
When is the next dyno tune?
How much does your car weigh? Be interesting to go from a roll on that private road you have
would also love to see pulsar......
what did it start out life as leroy????
Come tonight/tomorrow for food and will take you for a spin.
? the car? stock SSS, been through 2 U13 motors I think and then went GTiR motor... then I bought it and put another GTiR motor in it.
What was fixed?
Exhaust leak fixed.
Cihan got the tune done, so he's happy with it. Just asked me to make sure boost doesnt go over 20psi because he set it with the exhaust leak and just wanted to make sure it didnt go over.
Not sure how much car weighs... friend of mine is getting his keys to vicroads weigh stations soon, so just waiting on that. Am curious though.
#miguelone
what's part number for lower control arms? since ball joint is f**ked (maybe) i'm trying to see if it'd be cheaper to get new ones, or just buy 2nd hand and change ball joint.
or do i just rebush/re ball joint mine?
Edited by xALmoN
Poor guy :(
Is he bigger than me yet?
close... 85 cm odd
nah, mine were JDM 33
interesting...
Vehicle Type Car/Truck Victorian Registration Number JDM33 VIN/Chassis Number 6U9000ECR33015759 Engine Number RB25077780A Colour RED Make NISSAN Body Type COUPE Compliance Plate Date 04/2003 Year Of Manufacture 1993 Learner Approved Motorcycle (LAM) Not Applicable Goods Carrying Vehicle No Transfer Dispute No Registration Serial Number 1008347 Registration Status Cancelled Registration Expiry Date Not Applicable Sanction(s) Applicable No
#miguelone
Don't bother buying whole arms, grab Hardrace/whiteline/superpro/etc bushes and ball joints. Works out a lot cheaper and you'll probably end up with a far better setup in terms of handling feel etc.
interesting...
From this information I can conclude that your car wasn't a LAMS approved motorcycle.
I must tell everyone.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
