Artz lives in Frankston
Maybe he'll rent out a room
take your acar and get him to give it a rub for ya!
franga isnt as bad as people make out.
i wouldnt hang around the train station tho, and im an evil bastard.
got pulsar back last night, all fixed. hooollly shit. its quick. was supposed to be testing to make sure boost wasnt going over 20psi, I couldnt even pay attention to the speedo. wheel spin in 4th gear is pretty scary lol.
The good thing about Frankston...the police are too concerned with domestic violence and low scale. Theivery to be concerned with modified vehicles. ;)
this.
unless hwy meet.
dont go more than 500meters from the meet on your own or you will be defected.
What was fixed?
When is the next dyno tune?
How much does your car weigh? Be interesting to go from a roll on that private road you have
would also love to see pulsar......
what did it start out life as leroy????
Come tonight/tomorrow for food and will take you for a spin.
? the car? stock SSS, been through 2 U13 motors I think and then went GTiR motor... then I bought it and put another GTiR motor in it.
What was fixed?
Exhaust leak fixed.
Cihan got the tune done, so he's happy with it. Just asked me to make sure boost doesnt go over 20psi because he set it with the exhaust leak and just wanted to make sure it didnt go over.
Not sure how much car weighs... friend of mine is getting his keys to vicroads weigh stations soon, so just waiting on that. Am curious though.
#miguelone
what's part number for lower control arms? since ball joint is f**ked (maybe) i'm trying to see if it'd be cheaper to get new ones, or just buy 2nd hand and change ball joint.
or do i just rebush/re ball joint mine?
Edited by xALmoN
Poor guy :(
Is he bigger than me yet?
close... 85 cm odd
nah, mine were JDM 33
interesting...
Vehicle Type Car/Truck Victorian Registration Number JDM33 VIN/Chassis Number 6U9000ECR33015759 Engine Number RB25077780A Colour RED Make NISSAN Body Type COUPE Compliance Plate Date 04/2003 Year Of Manufacture 1993 Learner Approved Motorcycle (LAM) Not Applicable Goods Carrying Vehicle No Transfer Dispute No Registration Serial Number 1008347 Registration Status Cancelled Registration Expiry Date Not Applicable Sanction(s) Applicable No
#miguelone
Don't bother buying whole arms, grab Hardrace/whiteline/superpro/etc bushes and ball joints. Works out a lot cheaper and you'll probably end up with a far better setup in terms of handling feel etc.
interesting...
From this information I can conclude that your car wasn't a LAMS approved motorcycle.
I must tell everyone.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
