Martin what are your nuts made of?
If they're too soft (like cheap alloy ones) then they love to mangle themselves and fk up the thread of the stud.
I'd almost rather have a mangled stud than a mangled nut, since its easy to pop into a shop and pick up a single stud than it is to pick up a single MATCHING nut :P
Edit: Actually quite enjoyed changing a stud in the motel carpark at DECA, was a lot less painful than I thought it was going to be... Do S14's have little cutout areas behind the stud like 33s have, so you can bash it out and remove it without taking the whole assembly apart?
Only painful part was not having a hammer with me, so ended up using Anna and Luke's towbar :P Swung that shit like a baws...
yEAh the recheck is the trick...nip em up easy and recheck ...old man thought me years ago to do them up real tight, he would stand on the f**kers..so i would do this but I learnt over the years this was because he had a shit house wrench...add some decent leverage into the equation and they jus
Love JW black platts....especially at that price....not too fancy but not too shit either...its just right...specially with some dry ginger and ice...
I'm on the Bundy and coke zero tho tonight
In other news, Scotty ran right over my Nokia today in his whale..there was kumho tyres marks on it and all so i know it was him....
I had to defibrillatorize it a few times with my fist, but it Still works :D
yeah that said i did get a 25$ torque wrench form supercheap that does make a good wheel wrench...the fact it is a torque wrench is just a bonus
If something requires a torque wrench, I wouldn't be trusting a $25 one for the job.
+ 1 for using logic for everything else... I use a 60cm breaker bar, just a little tug on the end of it gets them to a good tightness, not overdoing it but def not coming off... Just keep those damn tyre shop rattle guns set to 10/10 away from my car and things will be alright...
Nokia tried to commit suicide, due to owner being a hack. :P
I can't believe it still works after being run over by 2ton of whale, twice. All hail the new Nokia brick.
Hey.
Anyone know anywhere where one can purchase something f**king mundane, possibly the most mundane of all Skyline bits.
A R34 N/A Series 1 Grey Front bar?
Bonus points for a rear bar and skirts, for a sedan.
Surely these must be lying in piles somewhere.
but where?
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
