Sounds good - I hunger some tempura
Yesterday I got rammed from behind by a guy in a Lancer, then we exchanged numbers :turned:
But on a serious note, he has no insurance and cannot speak very good English (been in the country only ten months). Luckily my insurance said they will wave my excess if I take down his details - also, since I'm not at fault, it will not affect my premium or rating :D
Still a pain in the arse having no car for a while.
disappointing lack of aussie racism in this post.
this is the complete opposite of what usually happens, non?
not at fault does not equal having no claims against your name? (in case of stolen car, accident with someone without insurance etc.)
Who says Alvin doesn't have a big banana? Dat BYC
Simon how does a company monitor employee internet usage. Are they able to monitor everything you do & how much time spend on the internet, apart from browser history?
I was also surprised when they told me this. I checked again to make sure but apparently this is the case; there will be no affect on premium or rating.
I too would like to know this.
It all depends on how the IT systems are set up...
Small business networks are often set up just like a home network is.
Computer -> Router -> Internet
If they have a fancy router, they could install some software on it which tracks requests and links them to users.
Larger business networks are often designed with forensic options in place from day one, or as a happy side effect of proxy server caching.
Computer -> Proxy Server -> Router -> Internet
All traffic passes through the monitoring server, which can be logged against a user if required... Websites visited can be pulled from log files (or automatically made into nice reports listing the sites visited and/or time spend randomly browsing reddit)
Obviously that is just a high level view of some generic setup, there are a lot more in depth monitoring solutions out there.
Just keep in mind that "Incognito Mode" does nothing, all that does is stops records of the visited websites on YOUR pc... Once the request for the site leaves your computer there is nothing to stop it from being intercepted and recorded against you.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
