ehh rwd more fun!
I seem to recall some bloke telling me to drop my shaft in GTR and drive a 'mans' car :P
Birds saw you turn left onto FTG road this morning was at lights waiting to turn right. /csb
Will have to keep an eye out for you, I thought you left 10-15 mins earlier than I do.
Drivers be all like, it's wet on the roads I better drive 40km/h slower because I'm such a shit driver that I'm likely to lock up my brakes in the wet.
Love straight out exhaust on almost any car just to see how natural and beasty an engine can sound. Used to do it to most cars I'd put up on the hoist.
But gawd, the day I took the mufflers off my R1 and started it up. Shit shook my car port.
short pipes/side pipes = hnnnng
normal exhaust length without muffler/cat or hotdog = pretty terrible. DECA is all about SR's and RB's with no mufflers and they all get kicked off track days when they go to a circuit. half because loud, other half cause sounds bad.
yea 160kw, 4wd. picked up an 02 for a steal.
can pick up classics for sub 5k, cheap fun.
The wrx club only allow turbo subies to join up. The 3.0RB has 180kw, but is ineligible... go figure
i know is bullshit.....
we can be in a club together mate. you with your 3 litre and me with my auto.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
