should have brought to me. did all 16 on micra in about an hour.
gentle love taps with hammer, some washers and an old wheel nut.
much easier than taking hub off to press
my studs are tack welded on. so not sure how to remove properly without damage. and also failed removing the current wheel nuts... pneumatic ratchet couldnt get them off.
Plus, needed replacement rotors machined down a few mm. so few birds with one stone.
thanks for the thought though.
tomorrow night (thursday night) meet at the new bunnings springvale (849 Princes Hwy, Springvale VIC 3171) at 9:15pm leave 10:15pm heading to docklands, got photographers coming along. :)
this means i need to wash the car before then somehow!
well if you ask any, im sure all will say yes. how many will send the work away to be done elsewhere.... not sure.
I think most machinists would do it, rather than just any old workshop.
Just bought 12x BKR8 spark plugs off the shelf at ferntree gully bursons. $4.50 each. notbad.jpg considering not many shops will even bother ordering them in for you. Just got to re-gap them all :|
So Bursons for bulk spark plugs and oil filters... Clayton Autobarn for huge Penrite oil selection.
How to make free money in 7 easy steps:
1. Be me and get $50 free bet from Sportsbet in email.
2. Deposit $50 to obtain $50 free bet.
3. Place free bet on 3 soccer matches in a multi bet paying 5.80:1 for a potential $240 profit
4. Win 2/3 matches
5. Hedge last match by putting your real $50 on the other team to win or draw, for 2.8:1 so you're at least guaranteed $92 profit even if the multi loses.
6. Your selected team wins and you come out with $190 profit from a free bet.
7. Have the self control to withdraw all $240 until they mail you again with another free bet or move from agency to agency,
  • Like 1
well local brakes place dont want to work on it because they have done it before and damaged hub. so will take it back to centreline. so will be there for cruise tomorrow :) but will need to hit Thomastown again sometime :(
  • Like 1
yo Alvin, trying to find copies of that movie you recommended: the Paella Magic one. Can only find rebellion, im on the hunt for the others. (save myself countless hours watching yet another melodramatic fantasy anime (i dont mind the first few hours, its beyond that when I want to shoot myself in the face))
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
