OK so i'm selling the Evo... anyone want?
Gonna buy a $5k RB20 C33 as a train station car and club reg it... then use the rest for a deposit on a CX5 for the family.
Actually kinda looking forward to it as I have always wanted a Laurel and I HATE the golf
Shouldn't have taken the Golf
Should have bought a Jeep
It's not a car, it's an Alfa Romeo
  • Like 1
dat Evo buyers regret.
Legitimate thing. No less than 4 people on here who have abandoned them in a matter of months.
Patiently awaiting Ishan and Scott to bail on them now...
but CX5? cant tow (much), no offroad capability... why go soft roader then? small-medium family car will do those duties.
1) you drive a pulsar, you opinion is invalid.
2) clearly it's a family car, not for off-roading or towing my non existent track car that I don't have.
Get an R33 Hamish
No.
They are great and I would still like to have one, but not as my ONLY car and definitely needs moar power.
Buy Hamish's
i do good pri for yoo.
be a man
so why not just get a ford mondeo or something?
cx-5 is basically a mazda 3 on stilts.
compare spec for $$ cx5 is damn good
and mazda 6 newer and better spec than mondeo
all these have been on my check list
new jeep cherokee has me interested along with Skoda octavia RS need to compare with cx5
Mazda.3 is well specced now days the jeep grand Cherokee is deff nicer but few more $$$
The crv is quite nice lookin and well kitted out to but gets pricey
not the grand Missus don;t want to park it.
the new cheerokee out next months,
looks interesting,
curretn reviews say they fixed all the hard plastics, 9 speed auto, plus could tow my race ar so I can buy a fun car.
I haven't driven mine yet, the 4 months don't kick in till the damn engine starts.
Should be a good car, like the other 3 cars I own at the moment. Will need to get rid of one at least once Barry gets it back on the road I think. Anyone want to buy an evo7 with brand new built 2.3 engine? :P
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
