Should be a good car, like the other 3 cars I own at the moment. Will need to get rid of one at least once Barry gets it back on the road I think. Anyone want to buy an evo7 with brand new built 2.3 engine? :P
lol.
when I was there last it was buried in a sea of cars. are they just doing an engine for it?
you'd think there'd be enough evo engine parts floating around that there wouldnt be much delay.
I haven't driven mine yet, the 4 months don't kick in till the damn engine starts.
I'll offer you $62 and a welding rod.
OK so i'm selling the Evo... anyone want?
Gonna buy a $5k RB20 C33 as a train station car and club reg it... then use the rest for a deposit on a CX5 for the family.
Actually kinda looking forward to it as I have always wanted a Laurel and I HATE the golf
JZ cressida up the road for 1500$..89 model....tis auto tho...but get t56 and install for plenty good times.......
not to mention parts for these cars and parts are ridiculously plentiful and cheap
also I love that you hate the golf...even if you had to buy one to figure it out :D
was 2 tossers on westgate yeterday...P-platers racing, a golf and a sil80....I don't know who won but they were both lame
Wait wut? Hamish in a rb20?
Lol really have been accumulating the parts, all that's left to buy is wideband and tune really. Although true enough that's the better part of a K, sad times.
I soz wallet, I soz.
I'll wait for Scott to get bored of his lol.
I shotgunned that car first
There's an 8 with 2.3 E85 and 515kw or something ridiculous like that in the for sale section.
Dude wants 36k (?) though...
working from home today :D (sitting on my laptop at kitchen table since 8am and havent really done a lot though...)
Toby. do it.
http://www.skylinesaustralia.com/forums/topic/442046-vic-xd9-emotions-brand-new/#entry7263215
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
