ive heard mixed things about that place. mainly crowding, average service and overpriced food. (but then again, what mexican isnt? (other than take-away burritos from shopping centre food court)).
wasn;t overly crowded when we went but there was a wait so we had a beer up the street for a few min.
the service we had was exceptional and was good to try a few new tequilas not had b4.
no idea of prices as paypal were footing the bill.
Mamasita is great, but it's not cheap.
amazing tequila selection but for Modern Latin food newmarket hotel is better (and a lil cheaper)
... but for Modern Latin food newmarket hotel is better (and a lil cheaper)
oh forgot about that place. went last year or year before. food was really good and place was really nice inside and out. menu was probably the most convoluted ive ever had to navigate though.
Leigh, is CAT looking for IT
your mate can have my job brah
lol nah jk's we all full atm!
check out the powerskid marks I down nantila from duredin heh lunchtime shenanigans
4:30 time to go home! booya. #longweekend #hashtag
Edited by UNR33L
more rage stories
be me
need fmic
buy bolt on no modifications required blitz IC
attempt to bolt on
doesn't fit
hi greg, enjoy series 2 bs again
buy reo and front bar, cause they go together
$650 later
look at new reo
is same between s1 and s2.
f**k SAKE.
more rage stories
be me
need fmic
attempt to bolt on
doesn't fit
$650 later
look at new reo
f**k SAKE.
Maaaaaaan. Was it your 34 I took the manifold off?
yes well we know he has repalced all that.
I'm jsut surprised that the cooler not fit as I didn;t think they would go to the effort of changing all that much crap between models.
on a side note
anyone changed Front wheel bearings b4?
is it as simple as this makes it out to be?
http://www.nissansilvia.com/forums/index.php?showtopic=523293
if so I'm doing this myself.
when we did it on my ute needed to use a puller to get the old ones off, not wanting to do that as I don't have one..that said any excuse to buy a new tool.
Way I see it is, I can pay someone a couple hundred to do it, or use that money to buy the right tools and never pay to have some-one do it for me again!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
