life is great
came back married after 7 week honeymoon
my best man and my brother in law suprised us by re-doing our backyard and putting in sprinkers and grass as the wedding present
in final stage of organising new car :D
pretty sweet :D
how are you and your brother
life is great
pretty sweet :D
Wow, that's kind of your best man and brother in law to do your garden.
What'd you buy?
I'm doing ok, just surviving really. Brother is hit n miss at best of times but he's ok physically.
What'd you buy?
yeah, pretty cool hey
they are both very handy in the garden and did a great job
if it the weather is ok today ill get a pic and show a before and after
brought an evo 8
should pick it up in a few days, just need to sort out the paperwork etc
hows your 33
Make sure to book a final inspection detail once your micolour spray is done :P
SAU brand whores represent....
you cant detail a fresh spray job anyway, Paint needs time to breathe out solvents..
unless you mean book in now because there is a 6 month waiting list ,as thats when it will be ready for detailing..
Wheres Tony....he got his car done yet?
  • Like 1
What am I getting done? :/
brought an evo 8
hows your 33
A evo 8? Nice, the 33R's pretty good so far, happy with it for time being - still deciding what I'd like to do with it as always!
you were getting DT to polish your car remember
Arghh, anyone happen to have some 205/(50or55)/16 91 load rated tyres for cheaps or 15/16" 5x100 rims with good tyres I could borrow for RWC? Need by Thursday!!!
errmm.....yes :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
