My cousin is after one, if the offer still stands I'll let him know..
What kinda damage are we talkin monica
18 years of general wear and tear + I think some of the mounting points may have gotten a bit mangled when it was hit.. I don't recall it seeming that bad, but I wasn't going to say no to a brand new front bar
Sounds alright, let me know if it's there for the taking
speaking of illegal activity... yesterday's car meet at carribean gardens: so many p-players driving turbo cars. turbo civic, stock 2JZ supra, A45 AMG, VW R36.
not sure if borrowing parents cars or just not giving 2 ducks
remember club reg not for a daily.
ie if you going to drive it to the train station ever days, you will breach the regs on it.
This is not correct anymore..
You can drive it for 90 days a year, as long as you have a logbook
Which pretty much means you fill out the logbook before you go, except the date field.
Get pulled over? Write date down quickly, and then you're good to go.
Mate with Club reg BMW has actually been asked exactly 0 times for his logbook the 4-5 times that's been pulled over/through a booze bus etc.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
