simone. mick says you has universal clutch tool!?!?!?
can i has use of for 10 mins?!
You may. I'll be home in Vermont South after 6pm, but I'm going out at 7:20 if you need it tonight. I can leave it in the letterbox if you want.
oh hai
new car is berry nice
hamish it has 2.3Lkit, 270deg cams, 1k injectors, clutch, flywheel, vipec and usual supporting mods with an evo 9 turbo on it
its tuned for 19psi and i havent driven it on 19psi yet, only 8psi and it flies / pulls awesome in every gear - made 240kw last dyno run
ah was just surprised the setting is even that low, as stock they run much higher?
then again you have a stroker... fun times.
mods collecting dust in my room and garage, need to strap them on to unleash the 2L milk carton fury
Anyone installed one of the HKS SSQ Blow off valves? Looking at purchasing this:
http://www.ebay.com.au/itm/NEW-Atmospheric-Plumb-back-Skyline-R32-R33-R34-RB-BOLT-ON-Blow-Off-Valve-BOV-/151073396294?pt=AU_Car_Parts_Accessories&hash=item232cad1646&_uhb=1
Wondering if it's better than the others on the market?
Ssq is fnf spec
yeah ive got no idea how it runs less boost than stock
my understand, at least from skyrine was you could never run less boost than the actuator spring
no idea how this is working
but its got an eboost 2 switchable between 8psi, 13psi and then 19psi
but stock i think is 19psi
Probably actuator is adjustable/weaker spring?
EJ20s will run less boost than actuator pressure if they're in Limp mode, I don't understand how it happens even without running the factory boost solenoid but it won't let it past 4 psi. I guess it must yank shitloads of timing to keep it down?
no idea
ill have to do some reading on the evo 9 turbo and the controller setup
my understanding was from the skyline setup
where you must run the minimum spring level, you can run higher, but not lower
get one of these.
http://gfb.com.au/products/blow-off-and-diverter-valves/deceptor-pro/deceptor-pro-ii--inside-car-adjustable-adjustable-bias-venting-diverter-valve2013-08-04-02-40-32855251378-by-gfb
you can adjust from plumb back daily to fully FnF style or in between all with a switch in the cabin!!!!!
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
