last engine didn't blow because of fuel... was just everything else sort of worked together to self-implode.
Once you understand the way ethanol and petrol ignite, you will see why e85 is so much better for engine longevity. Petrol explodes quickly at the top of the piston's stroke, when the crank is at tdc. That explosion has nowhere to push the piston till the crank comes around a few more degrees. This is why the rods/bearings need to be strong, they take the entire force of the explosion.
With e85 the explosion is slower and colder, meaning less force is exerted at the top of the stroke, more when the crank is at 90 degrees, which is the point of maximum torque, and least rod/crank/bearing stress. This is partly why you gain torque with a lower energy density fuel, and entirely why my stock engine handles 40psi up the straight at Sandown. ;)
man what the f**k is this shit, im just getting him to do a quick little run in tune so i can run it in properly.
shittttt scotty, sandy vagina and shit.
sandier than aaron the niggas,
which reminds me how is that nigga, i heard he was kidnapped by these whites and sold into slavery. f**king platsys cousins.
Hmmm interdasting.
Will consider it since things are back on the drawing board at the moment.
Considering having a chat to racepace about my oil setup, i have a feeling that is playing a role in my issues. Namely flow pressure and circulation with the cooler.
yeah because springs broke, causing rockers to scratch, causing cam lobes to be damaged.
all the while bottom-end bearing fails, rod comes loose, whacks the block and scratches piston an cylinder walls.
would E85 prevented that and engine would still be running 100%? I think not.
would the tuning required for E85 continually melt my external ignition coil? possibly.
would the extra power/torque cause enough power/torque to destroy my headset? possibly.
would the 50L fuel tank need constant jerry cans on standby? probably.
Oh man :(
That was first time around I believe... Not what happened last Saturday...
Ah mis-read it!
I don't trust plant juice.
Nah, can't afford to redo entire fuel system ATM.
Trying to save for a house/ fix up mums house.
Time to invest in something
I got this fabulous scheme you can invest in
Trust me im Asian
Shuttup terrorist
lol @ redoing a fuel system to handle E85. Bigger injectors are all you need, and a fuel pump, but most people do that anyway with their 98 petrol modifications.
Have switched back to 98 a couple of times and the engine is just so much happier on E85. Not even for the power; it's the smoother more consistent idle and feeling like a brand new engine compared to petrol, which you seem to be able to feel the mileage with. Starting in super cold winter is the only time it's not happy on E, but once she cranks you're all good.
Get on it! There's a reason you've never heard someone convert to E85 and say this sucks don't do it man. Even Hatish loved it. And lol my phone auto corrects to Hatish now.
There are a few reasons not to go E85...
The need for Jerrycans is one of the major ones since not a lot of regional centres have any E85 at all, so driving to Winton or DECA will use nearly a tank, then the track day, then the drive home...
I do 300+ peak hour km's each week in my car, I could easily switch to E85 (My pump can handle it, and my injectors are 550's... might need an upsize if I want to keep some decent overhead, I pass a few petrol stations with it each day), but its still the hassle of country trips which suck.
I'll do it in the future, but for now, I'm sticking to BP98
Lol @ autocorrect.
You just can't tell some people Birds... They need to go their own way, same as everyone else, as has been done for years. What they don't tell you at school is cars started life running on ethanol, and only converted to petrol due to it being virtually free to pump from the ground. Things have since changed obviously.
So... Your tank isn't large enough? That's a great reason... :P
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
