getting quotes for new tyres for hilux so boss can make a decision... stupid tyre sizes from toyota. 205/80/16. "butter cutters" (apparently). bit pricey for what they are...
Bob Jane tried very hard to sell me 245/70/16 reckons they would fit fine on a 6" wide wheel.
Tyre Factory across the road said 245 shouldnt be chucked on a 6" wide. I dont know if he's right, but theres plenty of people driving hiluxs with stock wheels and 265 wides or bigger on them. is it because such tall profile? or because bogan?
One of the SAU VIC main sponsors is City Discount Tyres Morrabin
Got some cheap tyres over the weekend from him for the daily
Paul is your man to chat to. You may have met him at some of the track days in his Bluebird
thanks for the reminder Toby, I forgot about them. guys there have done me some solid favours. issue is boss wants it done during business hours near dandenong so no use trying to sway him on that one.
i honestly have no idea what speed im doing most of the time
is it just me or is the speedo in a weird spot?
i get revs are more important but yeah i have no idea most of the time
i dont speed a lot, but in general i have to sort look around the steering wheel to check speed
never had an issue, but did initially notice it as a bit annoying with its tiny-ness lol.
This is some serious gourmet shit! Usually, I would be happy with some Seinfeld, but go springs this serious GOURMET shit on us!
I don't need you to tell me how f**king good pulp fiction is ok? I'm the one who watched it. I know how good it is.
But you know what's on my mind right now.. it ain't the movies on go
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
