See my Sister and husband are FIFO.
hyundai I30 and a stock Golf GTI
last holidays were Bora Bora and Japan...
prob drink less than any-one else in my family
so they not all like that.
We're working with the 80% figure here...Patrick is in the 20%...for now :ninja:
  • Like 1
Have+some+cream+_33b32b25e3e579547829796
I actually have met plenty of tradies in my time (as have most people) and as al said, this would be 80% of them.
I also have a couple of mates that work FIFO in the W.A. mines and guess what...
They are both 101% Strayan
They both drive heavily modified V8 utes
They only holiday in Thailand/Bali where they only eat white people food, get full sleeve tatts and absorb 0% culture.
They rock cheap shit +11ty offset rims
They only drink Australian beer.
They listen to nothing but JJJ all day every day
They watch every sporting event known to man
AND
They get wasted on EVERY... SINGLE... FLIGHT...
This fits most of the FIFOs I've met here in WA to a tee. Groovin The Moo festival was full of them, which is basically a JJJ festival.
So accurate, in fact, that you should consider a career in marketing; a profession that encourages stereotyping. Bloody marketers, stereotyping pigs, all of them!
  • Like 1
Girl I know doing life drawing for her hen's tonight... you working?
does the CT9 plug need to be wired in or is their a connector at both ends? If it just plugs in you are welcome to borrow mine for a day.
Also doesn't Scotty have an EVO that he isn't wen driving right now?
found a pink 2004 CS lancer at pick a part
and hey presto, same plug
the plug is part of the main harness - wired in the DSS box and the engine management system, who ever wired these things in will know if you have your seal belt undone
yeah so all good
v happy now
just need to "fit it" so that its in the engine bay
What I think hamish is trying to say is.
80% of fifo's are the stereo type he states.
and 100% of those fifos in his 80% barrier are tradies.
other 20% who dont fall into the stereotype, engineers :P
So, All fifo tradies are what hatish states.
Muahahahahaha
  • Like 1
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
