GTX3076
2.8 (comp is supposedly 8.2) - Stock exhaust manifold, stock airbox, 3in exhaust, automatic transmission (the slip up top was 8% through it), return flow cooler, etc.
As for how it occurred.. it really did occur at about 30kmh, driving in 4th gear (which is 5th for you manual people) minding my own business turning right, UNDER the 'advisory' speed for that corner.
I had 30 eggs in the passenger seat. None of them cracked. I hope this leads Mr Shannons Assessor to believe me when I say I wasn't driving like a tool in the rain and it was a low speed impact.
See photos I linked a few posts above with the imgur link
Or I'll just post it again -> http://imgur.com/a/2JKpW
Pretty much had a direct impact on both passenger side wheels - whatever holds them straight (i.e, rods of which I do not know/cannot define/of unknown origin) are clearly snapped or bent. Or I just got a free wheel alignment of about 30 degrees of toe at the rear, and a front passenger wheel which decides it doesn't have time to listen to the steering rack anymore.
There's a good fist/sized (in volume) dent in the front bumper too, right under the front indicator on the passenger side. I didn't take a photo of that cause I dunno, I was busy being rained on, and such.
it was right here -> https://goo.gl/maps/r4XxQ
There's a farm here -> https://goo.gl/maps/SAsmh that claims to sell the best eggs in the world. They're really good. What better thing to randomly do on a sunday than taking a nice relaxed drive through the hills to buy eggs, to just enjoy the fact your car is finally working, because it's far too wet to do any 'spirited' driving?
People saw the dyno sheet and asked me what its like to drive... I don't even know.
I'm just going to cry myself to sleep now.
Dude that sucks!
On another topic
Don't ever go to burwood hwy tepanyake. Had to go for a bday and now I'm f**ked with food poisoning.
Fkn disgraceful cooks were using the spatulas to turn the lights on/off and and used the same cloth the waitresses used to clean the tables and chairs to oil the stove
They don't even know how to fkn cook. f**king pissed me off more when you here some dumb f**k go oh he's a good chef.
/rant
Dude that sucks!
On another topic
/rant
looool sucks to be you....
especially today!
Inb4 Pat launches into tirade about 80% of chefs meeting this stereotype
that's fair, 80% of cooks/chef absolutely suck anus.
I worked f**king hard not to be in that 80% so stereotype away! ;)
  • Like 1
GTX3076
Sad to hear about the accident!
But that is an awesome dyno graph!
Got specs on the Engine build?
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
