Do you blame them Artz, one read of this thread is enough to scare off any sane person...
lol...u do make a valid point there...
nearly everytime i meet one of them they tell me how much hate they have for sau..
they all come running back when they need tech advice though
They are fine, im not spreading hate for them... but a few times I have mentioned SAU cor some reason and they will start spilling hate...apparently we are a bunch off assholes...but we already know that...
I guess you cant please all the people all the time
run by CSA
and having meet a few club members recently I don;t think they wankers, they do have a couple committee members who spoil a lot for them tho
both correct
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
