you word things weirdly. though i knew what you meant. just thought maybe you had done most of an epic marathon of some sort.
I've been doing an epic marathon for the past week and a bit lol
y'all whinging about someonewho has dialogue and a name nobody remembers being killed off.
back in OZ, average of 1 character death per episode. that shit ran for 6 seasons. OZ was doing it before it was cool.
OZ was the bidness
And sharpened finger nails, so boss
that scene was BOSS
Jumping on car list from few pages back.
89 R31 wagon, full of rust, parted out
88 R31 wagon, swapped for coupe roller
86 HR31 GTS coupe(base turbo not natro) bought as roller, sat, collected some bits ended up on eBay
91 Hyundai excel, rolled
88 Honda prelude, bought with front end damage, repaired, filled with coolant, leaking, figured water pump gave to workshop to fix/rwc, turned out block was cracked in accident, left it there.
96 R33 taxi, drove it, loved it, shat auto, took off road, threw money at, sat, got over it, parted out
93 R33 coupe, bought t boned, parts car, parted out
86 Toyota Corolla, borrowed off mum, shat engine, replaced with engine from other, shat gearbox long time later, mum cbfd so went to scrap
85 Toyota Corolla bought for $100, pulled engine, sold for $100
81 Nissan Bluebird, bought from original owner, low ks, dailied, shat head, replaced, cam gear dowel somehow came out of new head on test drive, turned both heads into 1 good one. Went to ballarat, bottom end died on way, towed, probably still at depot
95 Nissan Maxima, bought off sister to replace bluebird, now going to my dad
93 Subaru Liberty RS Turbo, new daily fun car
and you're still on your P's, yeah?
chasing a quote for a custom-made sump. any recommendations?
is scotty busy? car is off the road so will probably only be able to give stock sump and photos for an idea.
I have never made a sump before, but if you have pics I could probably copy some other design...
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
