http://www.skylinesaustralia.com/forums/topic/444127-round-1-sau-vic-go-kart-series/
Come on guys, get on it... You know how these things normally go, once we hit 5 or 6 people on the thread it starts to snowball into a big thing
Sure beats the crap out of 1st year junior apprentice $7.44/hour award.
how is that allowed? I know electrician apprentices often get shit-all, but a quick check on PayCheck Plus for full-time junior apprentice is over $15 an hour. i dun geddit.
Tell that to the thousands being made redundant
its sad thats theres so many positions disappearing, but not much different from food or manufacturing industry.
im down for kesh on the day. seing as its been a year and we still dont have pay pal.
That is a really chitty pay mate
Don't know how they pay you less than a bloke that just flips burgers
How many years before you on a normal wage of say $50K p.a?
My first job in a call centre was $19 an hour I think :\ (20 years old)
Pretty shitty job too.
I worked weekends for time and a half and they had some 'issues' (bugs) with the payroll system so ended up on about 64k p.a
Terrible job though quit under a year.
Edited by UNR33L
at least you get paid something while you learn, unlike dem uni fees.
Yeah there's a difference between Uni + Part Time Job and Full Time and getting paid the same amount for twice the hours... Normally not left with a $30,000 debt at the end of it though I suppose
Still have to pay for tafe doe.
Edit: and really I learnt just as much about a different field as a labourer earning 50k a year. Spending a week at tafe out of every month although paid is for the most part a massive waste of time. Units rated at 60 hours and such really only take maybe 2 hours to complete and then the rest of the day is spent sitting twiddling thumbs waiting for a teacher who's busy with other students (because classes are far too large and teachers are far too few so the tafe stays profitable) to sign you off so you can go onto the next assesment.
that's baller money... there is overtime etc
when I did my cheffing apprenticeship, first year was $7.20/h flat rate - paid for 38 hours and working ~80
Lol Pat has a cry about Hamish demonising FIFO bogans... nek minit all public servants lazy and useless. Gooby pls
lol PWNT
Completely different industry, never done any overtime as a mechanic.Although I'm sure it happens some places in my experience everyone seems rather more concerned with packing up 15 mins before knock off.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
