I'm not saying they don't work but really they are not very much if at all cheaper than Garretts and due to having a plain bearing core you do lose some response(and that cool whirr down noise after the cars turned off :P) I just don't see them as excellent value for money.
Yeah but with the Garretts you miss out on the left field R&D that Stao puts in to individually better each of his turbos, such as his FNT design, which makes a significant difference to lag. My HG is as responsive as equivalent BB Garretts pushing similar power and produces that power at a lower RPM - dyno graph was actually comparable to that of an HKS GTRS, but for half the price. This is using a Nissan comp cover too - gone are the days of highflows being laggy substitutes for a proper Garrett. Tony can attest how responsive my car is to drive.
He can do roller bearings and anti surge slots for Garrett money if you're prepared to pay for it, but there's really no point with smaller turbos - he's tested both designs and they produced much the same response. If you're not happy with a turbo he'll take it back and modify it until you are. Then if you want more power in future or to take advantage of upgrades he's made to turbos, he'll modify your turbo for a small fee. That's where I see the value in it...
How much? My mate is trying to convince me to buy a dirt bike...
6k flat with road reg till next year, (2009)
then i'll decide whether i ride it enough on actual roads enough or just rec reg it, possibly get motard rims and tyres too
there's definitely a lot cheaper out there if you aren't looking for road rego tho
also worth noting rego is cheaper under 500cc
Edited by UNR33L
dirt bikes are for bogans who like ruining forests and destroying silence for kms around.
i'd rather support hunters/shooters who actually enjoy the outdoors.
save your coin. for someone who lives at home, you sure do have a lot of space to put your toys.
FFS
The following things are awesome:
*RWD
*Meisters
*motorbikes
*buying a car that isn't an sss pulsar
When will you learn?
  • Like 1
Yeah, going to have to agree with this haha. Everyone on my Facebook who owns a dirt bike is a bogan, I find dirtbikes incredibly annoying.
Nah, love my car...not worth selling and I know I would miss it; supported by what everyone says here about their maroon R33s once they sell them.
But trying to decide if tracking it is the way to go, given the current exterior condition, or repair and respray for dat mint daily driver. Worried I'll miss it on the daily grind if I track the thing, worried about spending that much on a paint job and getting sick of it or it breaking in a few months / that's money that could be put towards an RX7 / something else stupid.
inb4 why not both...not getting a 3-4k paint job and tracking it.
Daily plus track till get epaed then get a nice daily..
This is the same advice I gave my brother, turn into nuts car until you get defected / EPA'd then take it off the road for track car!
FFS
*RWD
*Meisters
*motorbikes
*inserts compulsory image*
Dirt bikes are fun as shit! no different to the 4wd's that run through those places either
camping with mates and dirtbikes > camping with mates and guns / shooting at shit
only the bikes stay in the garage car is outside :(
Drive it down a winding, fast dirt road in the middle of winter, and never clean it.
Look at it, go LOL its ugly as fark
then just drive it hard, daily and on the track, giving little f**ks about what you cannot see when actually behind the wheel
i will cut you in your sleep
No tax return, hecs ate it all up :(
Dem uni loan lyf
you should always take into consideration the HELP/HECS repayment based upon your HRI dude
At least then you will know exactly what your tax position is
  • Like 1
knowing your tax position is easy...you just ask Tony!
which I must do soon as I want some more car parts.
  • Like 1
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
