Every paddock from chirnside park to eildon covered in frost. Bit nippy.
Apparently they closed down mt donna buang over the weekend cause so many people rocked up. 2hr queue up the mountain. Warburton was a carpark.
My Skyline was an ice cube, that's never happened to me before. Them warm water windscreen feels...
Unrelated:
http://www.skylinesaustralia.com/forums/topic/446385-fs-tidy-444rwkw-2530-det-r33-for-sale-may-sell-engine-or-swap-for-gtrstagea/#entry7357271
Hamish...do it fgt
Yeah had thick ice on all my windows, roof, boot etc... When I opened the door the handle had to be cracked free, and then a line of ice along the top of the window fell off when opening it.
PFC controller said 2c water temps at 8am, what temp does regular green coolant freeze at? Does std aussie coolant have antifreeze modifiers added to it?
Yeah assuming infinite grip, that would be like 550 in a GTR
But I suspect burnout machine unless you're into 300km/h+ highway runs
burnout or slide....
wouldn't be cheap on tyres that's for sure
itll have antifreeze in it just a much much lower concentration then a british or canadian coolant.
funny, we call it coolant here, we call it anti freeze in the uk.
also, in for half a sec start up on e85 this morning. anyone other than haim have issues?!
Took me about 15 goes to start my car yesterday. I suspect it may need new plugs though.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
