That's why I just go Nexus all the way to the bank... cheap outright purchase price compared to Galaxy Sx or HTC Onexx models... and its stable as everything and latest version of everything
Not saying it doesn't work, but do you not see how that stolen car strategy wouldn't work if there weren't people who do the opposite of these guys and actually visit the forums outside of needing help? Can you refute the P2P leecher analogy? All take and no give is what I'm getting at. They only wanna know the community when they need.
I'll happily keep an eye out for some stranger's stolen car. Conversely, I get annoyed when the same type of people just chime in on a wasteland discussion lol. We know nothing of their financial / lifestyle credentials and they wanna talk shit with us? FOH
  • Like 1
Went android for a week, and switched back to Apple purely cos android annoys the shit out of me.
They're not that good as anti-apple people make them out to be.
Inb4 haters.
Just bought a nexus, instead of a new screen for pretty much the same money... new screen was going to cost $280 coz i broke some other important thing in the phone, and the nexus was $320 delivered lol.
Looks mad, lets see how it goes!
Yeah but where is that stranger when your car gets stolen
But +1 for uninitiated VWL strangers
I get what you're saying and I agree as well. I bet these people would be the first to jump to help find our cars if they got stolen :P
  • Like 1
so I've been playing round lots with android/ios lately since getting new iphone and new samsung tablet
and have concluded..
who gives a fk
just use it
this ^
also, was listening to an hour long mix on youtube of 90s songs the other day, for some reason picturing hatish djing in the ghetto' with his big ass beard (nohomo)
so much different to club songs today thats for sure, strong feels of primary school discos
while i was gone, did I miss any r34 front bar raps?
Edited by UNR33L
Lol
I love Aussies doing well on a world scale in anything but don't pretend you had any sort of interest in *insert seasonal sport here* until you heard it on the news!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
