So at court - observing not guilty of anything! I truly don't think I've seen so many polished turds in one place.
Baggy jeans with dress shoes white billabong belt tucked in Hawaiin shirt with a man to man suit jacket with popped collar
Classssyyyy
  • Like 1
is my membership still current? it says that i am but i dont think so
Mohsen Younes
Standard
Started: 19/09/2011
Expires: 21/09/2014
You just squeezed in with a week to spare ;) Renew for another year at the cruise or we'll throw eggs at your car and chip off all the bog from the rear guards.
so suit cases:
I really like Samsonite.
Strong good warranty and light, but yeah $$$
my suitcase, suit bag and carry on all Samsonite and moving up to this one next week:
Katie uses antler nearly as light and very happy with that.
But alot comes down to how often you use it.
If it's once a year do you want to spend 5-600 on a suitcase, probably not.
if looking at something a little cheaper I strongly recommend American Tourister:
http://www.strandbags.com.au/luggage?filterset=filters&filter=BRAND&filtervalue=American+Tourister
it's Samsonite "cheaper" brand. so they slowly get the older Samsonite tech and good build quality.
Also never buy black unless you want to be one of those folks that has to check every bag on the carousel
.and customize it a bit.
All those free stickers you get with car parts i've been putting on each side of my old one so I can spot it a mile away.
Even some ribbon or a strap, just something to help spot it from a distance when some-one has grabbed the wrong bag is is heading off with yours.(yes this happened to me)
so suit cases:
Ha that's happened to me also, mine was leopard print though.
I have stickers all over my suitcases too :)
Classssyyyy
Dress rehearsal for the upcoming spring racing carnival
mate bought an R33 GTR, that had been in a small accident, got it home, thing wont spark or start, fuel pump wont engage.
proper dead.
then we found out the previous owner had ripped half the fuses out and drained the tank before insurance looked at it to ensure he gets paid out lol.
all good besides a cooked ecu.
feels good helping dream boats after being through hell and back with the same shit.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
