This is what the dyno correction method is meant to do... bring everything back to a baseline... But it never does...
So I never look too closely at the figures, just the shape of the graph compared to previous tunes on the same dyno.
My current tune is 243rwkw on an angry dyno, and it would be about 265rwkw on trents dyno, and maybe 255 on racepace judging from what I've seen from others... Either way, I'm happy with the good midrange I have now
  • Like 1
whats the difference between the 33 and 34 clutch?
the exedy HD 33 clutch is like $350 for the 33
and for the 34 its about $750???
wtf!? why the big price difference?
am I missing something here?
R33 clutch -
http://www.ebay.com.au/itm/Exedy-HD-Clutch-Kit-NISSAN-SKYLINE-R31-R32-R33-RB20-RB25-GTST-/181244122063?pt=AU_Car_Parts_Accessories&hash=item2a32fdd3cf&_uhb=1
R34 clutch -
http://www.ebay.com.au/itm/EXEDY-Heavy-Duty-Clutch-Kit-Nissan-Skyline-R34-GTT-RB25DET-NSK-7333HD-ER34-/121141141069?pt=AU_Car_Parts_Accessories&hash=item1c34931e4d&_uhb=1
R34 may be pull clutch, which is a more complicated and expensive thrust bearing setup.
apexi RSM installed
cannot wait to check out 0 to 100km/h in the evo
reckon its good for under 4 seconds?
I reckon you'd need about 260ahkw to pull that off
R34 is pull, I had a chromolloy fkywheel, didn't really feel much different ti stock one and really just made it a pig to drive at low speed, specially coupled with the libs laggy turbo and stupid tall gearing.
This.
Bombtrack had one in his 34 and it was shit. Sucks ass driving at low rpm and car didn't Rev any faster or perform any better than the stock flywheel
why is it always the high reading dynos that are wrong....whos to say the low ones aren't wrong?
thats my theory
also my NPC lightened flywheel was great ,its more a midweight than a light though...definately helped it rev up into the zone quicker.,..just made the throttle feel lighter in general and the engine more lively
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
