Most of the places I do cash jobs with give an invoice.
it's more they not paying for transaction/paypal/whatever fees
and also have the money there and then not in a few days times when the bank feels like it. (but that usualy when doing goods)
that said when just paying for services, cash jobs whole diff matter..
Not before you question the mark-ups these mahf**kers are putting on their shoes, in the knowledge that people will queue for days to get them ;)
Rich game, no f**ks given.
Half our retail though it's based in U.S / Canada so probably normal for them.. Some of the shoes are pricey I haven't bought on there but Googled em feedback was all pretty positive
Yeah I meant cheap for US...Even US sites airmax go for $130 ish, unless on clearout/sale/old as f**k models.
They don't have the ones want anyway so yeah
When I do cash jobs, it's to avoid paying tax
I plan to build a wagon like that one day. I've had a few turbo falcons, one of them was a EF fairmont with a little TO4E on it. It was manual and made full boost by about 2500rpm. 250kw of external gate goodness.
+ 1
If you need assistance send me a PM and i'll see if a cash job can be done
I need an unconventional engine rebuilt. Any help welcome... esp if the shop is in Clayton.
what unconventional? rotary?
3 cylinder 1L daihatsu engine :D
It's got no compression on one cylinder. Bought it as parts car for my gf's Cuore, but it's actually in better nick than the one she's got, so rather than pilfering it for parts, if I can get the engine redone cheap and put it back on the road, I can flog her existing Cuore off and keep the parts car.
I can engine out myself.
Well he builds all sorts of engines
He probably rebuilds an engine a day, not just high performance, lots of insurance ones. So i'd say he's dealt with a wide variety
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
