i was gonna get a VL but this has got leather mang. bitches love leather. and easy to clean when it gets full from sand when we hit edithvale beach this summer. gonna be siiiiiiick
^ this was my actual logic for the gloria
I was gonna get a corolla or a cruize for 10k but this has got some power and it interesting and it's got 4 doors which makes it a sensible daily driver.
^ this was my actual logic for the evo.
Called Shannons to modify my policies...
Skyline went from Daily $13k / $1800 to Extreme Limited Use $13k / $1240.
Evo Daily $15k / $1200something as well
Urgh :( Was expecting the Skyline to drop under a grand considering its able to be driven only 2-3 times per month.
They also said I could rock up without an appointment to the Shannons center in Cheltenham and get one of their blokes to sight the car and the replacement value of all the mods... and a $23k agreed value ($10k more) would be about $35 extra per year.... uwot?
tell them you have camms licence?!
gives you a discount man.
A customer asked me if we sold leather seat covers today.... Now it all makes sense.
Sign up for the racv vintage/classic insurance. There is a thread somewhere on SAU
I was able to get my car in with shannons for 30k without them sighting it... I was curious to what i'd be able to wager if they saw the thing. Probably less.
Especially if they ask me to start it right now....
R34 ineligible for RACV classic. Too new.
Does feel kind of dirty seeing a R33 GTST eligible but a R34 not. :P
Yeah it sucks the Series 1 is eligible but the Series 2 isn't haha. I think next year it will be though?
Nothing stock looking about that engine bay either...
Pod filter coming out the side of the airbox which kind of defeats the point
GT40 low mount isn't exactly stealth material
Show the bay from the side and it's a different story
Good sleeper from the outside though, you would fool every seriously fast car on the street
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
