Need wasteland guidance...
Had a set of AVG Model 6 in Silver (Staggered 17x8/9) on the skyline when I bought it, just bought an identical set in White (Staggered 17x8/9) since 4wd diffs hate stagger
Will sell the 17x8 set and run the 17x9's on the emo.
What colour should I respray them? Currently leaning towards the white...
Thoughts?
alienware is all aimed at gamers yes? Can't see myself every using it for gaming, but I'll look at the range and see if anything takes my fancy...Will hit you up for discounts if go down that path...
The price on the Dell site for the XPS15 I linked above says including 20 or 30% off, do you get a further 10% off that price or only off the retail?
Leigh, had never heard of MSI til yesterday when I looked on scorptec/centercom... they're aimed at gamers too I gather..?
Unfortunately not, only 10% off retail.
10. Coupon discounts cannot be combined with any other sale, discount, promotion or coupon.
Thoughts?
First everyday of the week... Or black
Where dem valve caps at?
You want em?
15-inch MacBook Pro with Retina display
15-inch: 2.5GHz
with Retina display Specifications
  • 2.5GHz quad-core Intel Core i7
  • Turbo Boost up to 3.7GHz
  • 16GB 1600MHz memory
  • 512GB PCIe-based flash storage 1
  • Intel Iris Pro Graphics
  • NVIDIA GeForce GT 750M with 2GB GDDR5 memory
  • Built-in battery (8 hours)2
  • Available to ship:
    Within 24 hours
  • Free Shipping
  • A$2,999.00
ZOMG Free Shipping!!!!
Not white. A colour dark enough so you can put illest stickers on each spoke.
Do the 9's fit ok? No poke? 245's?
so funny lel... you can get illest stickers in dark colurs...
troll fail
Also go satin black Simon... as martin said it looks tits teamed up with some carbon.
you can even get a boss result from rattle canning it in that colour if you are careful
Possibly the most hipster thing I've ever had the displeasure of skimming through.
Referring to Glen Iris as a leafy suburb wtf
Micro herbs and paleo pancakes, go fk yourself
  • Like 1
Fk i hate this "paleo" craze
I hope research in like 5 years time shows it causes ass cancer
it already has albeit indirectly, from all the foodie wankers ass f**king each other over it.
loving this, a store that really understands their guests
"Prior to their departure, visitors to AK Duty Free can relax at the AK Lounge, enjoy a cup of espresso, and sample our wide selection of top brand-name cosmetics. In addition, we have a “Shopping Manager” standing by at all times to assist our male customers, and we provide personalized product shopping information, a highly popular service with our clientele."
Duty Free in Seoul airport,
So you give the wife's list of cosmetics she wants, and they go grab it all whilst you have a coffee and your done..
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
