Fucking well played CUB... well played.
That stunt took a serious set of balls!
so glad I never got on the slagging off VB bandwagon right now lol
my only gripe is the f**king RRP
Some of the first beers I ever drank as a kid were VB's... stolen from the esky while camping over easter... I had tied an onion to my belt, which was the style at the time. Now, to take the ferry cost a nickel, and in those days, nickels had pictures of bumblebees on 'em.
I remember VB tasting horrible, but we drank them anyway... After that I avoided them like the plague, but a few years ago (~25yo seasoned beer drinker) I had no choice but to have a stubbie of the stuff... Did not mind it at all :unsure:
thats how you know you have a girlfriend, not a boyfriend.
I can think of other ways
Gimme five bees for a quarter!
  • Like 1
VB isn't great beer...and it should be priced as such. shit is $48 RRP now
On Tap it's nice but bottled it's not that great and for some reason kind of inconsistent (may be storage related)
If it was $30 i'd buy it all the time
heading home today, will be hitting a VB when we get to Roma airport. after being a 38 degree dry camp for 3 weeks, will certainly look like something from one of those 80's beer ads...
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
