i just had an asian family walk into the store, and everyone had an aussie accent.
when i say aussie accent, i mean, like birds after hes had one too many vb's some pingers, a point of shard and a hoon around in a VN 5litre.
mind blown.
Who would have thought you'd hear an Australian accent coming from Australian people in Australia
You racist f**k
  • Like 1
You racist f**k
ill eat your f**king dick flamin mongrel.
Lol nick was about to post that!
You bitches coming along to the SAU Christmas Drinks on the 20th of Dec at the st kilda rd Belgium beer cafe (or whatever its called now)
Will be a good day/night... Clear your schedules, make it happen, stop being bitches!
the last time i went to that i woke up in my car at home, down a grand.
ooo i can make this. will be down. happy to chauffeur people in the gloria. i owe you the evo passenger last time anyway.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
