75ish,
but over a year wait last I heard.
By the time you add on roads and an option or two won't see much change out of $85k at best I reckon and i bet there is zero negotiation room with such demand.
Amazing car got to drive one and the quality is really good but thing that would annoy me is basically an a250 with the kit looks identical ..
Sometimes the shit ones are marginally better in the dry, which was the case when Federal 595s first came out and dominated dry slalom in a couple of magazine tyre tests, edging out Michelins and Bridgestones
The wet is pretty much what seperates good tires from shit tires...Most are the pretty much the same in the dry...
I disagree on this one massively..
I agree on my ute I cannot tell the difference.
but when pushing the S14 there a world of difference.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
