Maybe try some A050's , though I've heard they're not very good in the wet either :rolleyes:
ao50, if the road isnt like a lake, theyre awesome in the wet.
also. wtb. security guards.
Dat Taga prepped 34R was pretty farken planted on the deca skid pan that super wet deca last year where the skidpan pretty much was a lake lol.
Also, just bought another RS this morning, flying to Shitney Saturday to pick it up
One day you'll have an RS actually on the road... and that day shall be sweet
Well, he had one on the road.
I'd know cos I raped the clutch a bit.
Nah I'm probably going to revert mine to stock and sell mine, this one cost me pretty much the same coin and is far tidier, also has sunroof.
whats not stock about yours?
didnt you do this with the last RS you had? (except was damaged) whens it going to stop miguel, when is it going to stop?
gc8 4 pots, gc8 susp, gc8 steering rack, whiteline alk, resonator deletes, 3"tbe, f&r strut bars, koyorad, alloy rear swaybar c links. Will all make their way onto new wun whiteline f&r swaybars it already has. stock bits onto grey one.
This will be the end... curent one was supposed to be the end too but they're so much car for the money gaddamit.!
its like we're losing you Miguel. Enough is enough.
Depending on insurance situation and love for the vehicle of course...
The missus had third party fire and theft on it so it's covered for 3 grand worth of damage. Luckily I was on the policy so I could sort stuff out without her here. Fingers crossed it's not written off but they did a nasty job inside the car.
She loves the car though so it's going to be rough breaking it to her when she comes back from her cruise tomorrow.
Our lease is up in Feburary so I think i will look at a better suburb. Didn't really do too much research when we first moved here at the start of the year.
I tried that and had my car stolen lol, good luck brah Edited by HEKT1K
I'd do one for my R33 but it'd just bounce up and down too much to make sense.
Hell it's dropped 3 times since I've owned it, and when I bought it in 2010 it had "84600" after being imported with "54000" in 2006.
Yeah ok....
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
